Posted by Owen Aaland on September 11, 2011 at 19:52:00 from (216.47.32.147):
In Reply to: 826 MCV behavior posted by CNKS on September 11, 2011 at 10:23:03:
The steering has priority for the first three gallons of flow from the MCV pump. This flow has to go either through the steering system or bypass at the steering pressure relief valve. You know the flow is present because you have pressure for the brakes and TA lube.
My guess your problem is either the oil is bypassing the steering relief valve located in the bottom of the MCV or the steering pilot valve is sticking. The pilot valve is located on the top of the clutch housing. If your leak is from the top of the clutch it may leaking at the pilot valve and could explain a change in the steering when the leak began. A more common place to leak is the IPTO gear seal in the front of the TA. If the amount of oil leaking changes depending on which TA range you are in most likely the sealing rings and carrier sleeve are worn in the TA and the oil leaking there is just too much for the seal to stop.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
