Posted by TMonton on September 04, 2011 at 09:10:27 from (76.214.110.48):
I have IH D-10 carburetor on a '45 Farmall H that was a mess.
I have just cleaned and put a rebuild kit into it. Ironically the kit came without any instruction and am playing off the IH manual. I am real close to a startup once I change oil, filter and ignition stuff. Non-magneto.
An out-of-box first time adjustment as I remember is as follows:
Low idle ... is a no brain'er.... makes it idle nicely.
Top Jet (closest to the manifold) is the idle air mix. Bottom out the needle and back off to 1-1/2 turns.
Bottom Jet (base of the float bowl) is the high speed mix. Bottom out the needle and back off 2-1/2 to 3 turns.
Fine tuning would be under load and tweek the high speed mix so not to run too wet but still not stray too far away from your start point.
I know that these carb's are fairly forgiving for a first time run. I just want to assure myself I am still working within basic specification.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
