If you decide to check for a good spark like mentioned above, take off the desired plug wire FROM the Spark Plug, and hold the end of the wire to a GOOD ground on the tractor somewhere. Usually the bolt that holds on the coil. If you hold it close to a good ground, you should have a good spark. If not, check ignition components.
After reading your posts, it does sound like a gunked up carburetor. Be careful with the float becuase it is "bent" and adjusted to a certain point. When you take it apart, shake the float around and see if any gas is trapped inside. If so, its time for a new one....unless you find the hole and can solder it closed.
Today's Featured Article - Gatherin of the Orange - by Rick Nikolich. In July of 1998 I was talking to fellow Allis Chalmers collector Mike Schilling about the annual "Gathering of The Orange" AC show coming up in August of 1999. He got this wild idea that we should get a convoy of AC tractors and drive them from Charlotte, Michigan 105 miles to LaGrange, Indiana.
... [Read Article]
Latest Ad:
[More Ads]
