there is an extra hole in most of the oil filter housings that has a plug you can remove and plumb a line up to the valve cover. If not just put a tee before guage and run line from there. I have seen lines go in where the oilers were or holes drilled in cover. Have seen some with shutoffs some just lines running oil full time. Depends how well it seals up I guess. I think the only limit on head milling is when you run out of material between the water passages.If those pistons are 8000ft also they will stick up about .300" above the deck. Might want to do some math, don't want your compression too high with a mag, timing curve issues. Plus the higher the compression the higher the voltage required to fire the plug.That being said, that combustion chamber is huge. A Heisler head used a combustion chamber that was approx .300" lower than the IH head .
Today's Featured Article - Gatherin of the Orange - by Rick Nikolich. In July of 1998 I was talking to fellow Allis Chalmers collector Mike Schilling about the annual "Gathering of The Orange" AC show coming up in August of 1999. He got this wild idea that we should get a convoy of AC tractors and drive them from Charlotte, Michigan 105 miles to LaGrange, Indiana.
... [Read Article]
Latest Ad:
[More Ads]
