The constant mesh gear at the very front of the trans counter shaft (botton shaft) and the gear on the input (driving) shaft are under load when the trans is in any gear but 5th. The PTO and the Hydraulic pump (Liftall) are also driven from that gear. If it has a chip, or broken tooth, or a piece of netal imbedded in it it will Knock. It is esaily seen through the Belt pulley mount, W/O removing the trans top. It turns modestly and might just be the issue. I am sure you checked each tooth when transplanting the gears, but a cracked tooth can go un noticed. Best of luck, Jim
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
