Posted by keithg on August 26, 2011 at 10:27:55 from (173.19.48.79):
I had removed the belly pump, clutch and short shaft between the clutch and front transmission coupler of a 47 M so I could replace bearings and seals on the transmission countershaft and upper shaft.
I see the flywheel surface has small cracks and it appears the rear crankshaft seal is leaking. As I understand, the tractor will need to be split to remove flywheel for machining and also to fix the seal -- Is that correct?
It may be a while before splitting, so I am considering putting the clutch, drive shaft and belly pump back in the tractor now. Assume I would put in a new throw out bearing now.
Can you split the tractor and get it back together with the belly pump installed? Or do you guys remove the pump for better access? Thanks.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
