Posted by El Toro on August 24, 2011 at 07:56:08 from (108.15.86.54):
In Reply to: Farmall c value posted by Jacksonduper on August 24, 2011 at 06:45:44:
You need to pull a plug wire and see it there's any fire to your plugs. If there's no fire clean the points with some 320 wet or dry then check for fire to your plugs. If you have a distributor you need battery voltage for the engine to start. An easy way to check that is with your ignition switch in the on position and the points open you should have battery on both small terminals on your coil. Use a volt meter or test lite when checking for voltage.
If there's good fire to your plugs check your fuel system by disconnecting the gas line at the carburetor and see if there's a full stream of gas from the tank. If there's just a trickle your gas tank is dirty and needs cleaning and carburetor probably needs to soaked in carb cleaner and the jets blown out.. Post back what you find. Hal
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
