Posted by Janicholson on August 21, 2011 at 08:47:35 from (199.17.6.66):
In Reply to: Re: manifold problems posted by JR FRYE on August 21, 2011 at 07:36:31:
Nope, the stress on the pipe is heavy enough to wiggle it loose. If you clean it up with an abrasive disk on a 4" hand held grinder, it can be tapped as I indicated earlier. If you are careful, it will even look good. The threads rust between the pipe and the cast iron of the manifold. as they deteriorate, the strength goes away. One of the most prevalent and destructive factors is that water flows down the exhaust pipe i=on the outside and enters the engine through the bad fit of pipe to manifold. Because the tap cost so much, it is often passed by, and some coupling is welded on. (usually with 6011 plain steel rod. That can never work.) The tapered pipe threads are easily tapped deeper into the manifold. If you can t clean it up enough to tap, having a Nirod welded coupling put on it professionally, allows the visible part of the pipe to be replaced as needed. Been there many times, Jim
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
