Posted by ih560 on August 16, 2011 at 09:30:25 from (63.131.193.36):
In Reply to: Engine parts for A posted by d beatty on August 15, 2011 at 15:49:22:
If you truly do need a New oil pump, they are available, but well over $1000, is there really anything wrong with yours? These engines, aren't like Small block chevys, where you replace the oil pump at every rebuild because they only cost like $40. I know rebuilt cams and tappets are available and I can get them for you, but you are looking at between $450 to $500. Then Connecting rods are going to be fairly expensive too, but there is that set on ebay. Why are you replacing all these parts, this is a fairly low RPM engine, and nothing so catastrophic should have happened that wiped all this out, if it did, you would need a new block anyway. I really think you should just look into another engine, if you really need all these parts and then transfer them over to your original block if you want it to be the original block.
From what I am reading, it seems that you are used to rebuilding automotive engines, and just think that it is normal to change all these things with a rebuild on these tractors, but it is not. I have had customers like this before, and I really try to convince them not to waste so much money when it is not necessary. Cam and tappets may be a decent idea if yours are really worn but I would not replace the Oil Pump and Connecting rods, unless they really are damaged.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
