Posted by John T on August 15, 2011 at 18:55:44 from (173.243.181.15):
In Reply to: Ignition??? posted by Cathy M. on August 15, 2011 at 18:24:27:
Iffffffffff the tractor uses a 6 volt coil with a series in line ballast resistor between ign switch and coil I agree with BT in NE.
If thats what it has and its (the ballast) bad/open or a wire is bad/open/broke off etc the coil is gettign voltage ONLY WHILE IN THE STARTING MODE.
Put a 6/12 test lamp on the coils input (NOT to distributor side) and turn the ignition on and it should glow. If not and it only glows when shes cranking, then the ballast or a wire from or to the ballast to the coil is baddddddddd.
If alls well with the ign on and if points are closed there oughta be around 6 volts at the coils input but when you crank her over it should rise to battery voltage.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
