Posted by pete 23 on August 10, 2011 at 19:58:39 from (74.32.234.149):
In Reply to: 1066 no flow posted by 4960jd on August 10, 2011 at 08:44:59:
OK , assume hitch work correctly and lifts a heavy load same as it always has. Do you have a check valve block in the circuit to the aux valve outlets. If you do , suspect that, as o-rings blow in them and just return oil back to sump. Just put one in today on a 560. It is rare that a 560 has a check valve but this one did. Lot of 66 series have them. If that is not problem, I'm betting hitch doesn't lift properly either and you have an internal leak, probably under the right front corner of the draft control housing main rear cover. Air pressure test would verify that. Works best to check with air when pump is off but there are other ways of doing it, like back through the aux valve but you have to have a pretty good idea of the flow through system.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
