First off I agree with Ol Bob there below. That being said, Id feel more comfy if I actually knew the coils primary winding resistance as measured between its little + and -terminals. If its in the vicinity of at least 2.5 prefferred 3 and over ohms, Id say it should be suitable for 12 volts no ballast required. Some lay persons call those "internally ballasted" or with internal resistor (which isnt so, see
HOWEVER if its less then 2.5 ohms, especially if its more like 1.5 THEN ID CALL THAT A 6 VOLT COIL OR "12 Volts for use with or requires external ballast" and Id expect it to overheat plus the points burn up quickly..
The other possibility is if the coil is only marginally suitable for 12 volts (say its internal primary resistance is 2.5 ohms) and the alternator is taking the battery up to over 14.8 volts THEN THE COIL MIGHT OVERHEAT
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
