Re: Bizzare temp issue - Farmall H
Posted by Tom Fleming on August 06, 2011 at 02:25:01 from (75.145.35.236):
In Reply to: Bizzare temp issue - Farmall H posted by Dan G on August 05, 2011 at 17:55:08:
I the H thermosyphon or water pump? If thermosyphon, there is a simple answer: the thermosyphon works on gravity. If the nose is pointed down hill, the openings to the radiator are in the front, so the hotter coolant will be trapped at the rear of the engine to a certain degree, and hence you see the temp rise. Once you level out or go uphill, the coolant can circulate through the opens as designed. since you are rarely in a down-hill position for extended periods of time, I would not worry about it.
If you have a water pump and thermostat, then I am a bit perplexed.
my opinion.......
ps. just re-read your post, and saw you have a water pump. so, I'll let the above in place, but it doesn't apply to you situation.
This post was edited by Tom Fleming at 02:27:22 08/06/11.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership, ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
