Timing is a little complex on a mag. There are four things affecting the timing. 1]Gears in the front engine case (probably correct) 2]Position of the mag on its mount to the engine (adjustable to have the click of the impulse coupling happen at TDC) 3] The impulse coupling and mag drive (sets retard timing for starting (click) then goes to full advance for running the tractor) 4]Rotor gears in the inside of the mag. (aligns the rotor with the correct spark plug wire terminal) (your issue) The rotor must be timed to the internal mag shaft gears. It is hidden where the points are located. On autos the distributor cam shaft and rotor are usually concentric with the input shaft inside and below the breaker plate. on this mag, the rotor is offset with gears. The rotor is not timed visually, it is timed by the marks on these little gears. It must be ahead of the plug terminal such that when it fires the impulse, that it turns just in time to direct the spark as the spark is generated. Jim
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
