Other than the comp ratio of heads could be different, the ignition systems have several different spark advances. Magneto was basically 35 degrees , batt ign could be 40 ,30, 25, 22, or 16 so that would be one place I would check out. Some minor changes were made in carburetors, main jet size, air bleed size or blocked air bleed on some power packs. Valve length will tell you which head you have but of course you can't tell that without disassambly. You could check the head numbers under valve cover. A worn out govenor will make a gutless wonder also along with the proper adjustment of govenor internal linkage.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
