Posted by ohio03trdtaco on July 13, 2011 at 09:58:24 from (208.66.214.251):
Well I took the pump off for a rebuild. I found the gear was wobbling on the shaft a little bit. The washer was bent up to hold the nut from backing off and the key was in place. The nut was only finger tight though. So I figured some one hadn"t put it back together right and bought a used pump. Now the other pump is slightly different style. Will bolt up and work fine.However the drive gear is in exactly the same shape. It is a little loose and wobbling on the shaft. So is it normal for that gear to wobble a little? If it is I will probably just use the original pump, do to wear patterns on the gears. I haven"t tried IH yet but can I source a new gear?
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
