Re: squealing noise when ta is engaged
Posted by mkirsch on July 12, 2011 at 05:16:17 from (64.80.110.75):
In Reply to: squealing noise when ta is engaged posted by thomas gipson on July 11, 2011 at 13:24:03:
You just had this work done and it makes the noise?
Who cares what it is at this point? The dealer/mechanic should make good and fix the problem(s). What do they say?
As for the remote, did you replace the correct remote valve? Under the seat, left is right and right is left.
Did you get mixed up and reinstall the old, bad valve?
Is the problem always with the same implement? Have you tried different implements? Have you tried the same implement on the other valve?
If you replaced the correct valve and the same thing happens, either both valves are bad, or the hydraulic cylinder is bad.
Valves and cylinders can be rebuilt. It's usually just a matter of replacing worn orings and seals.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership, ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
