Connect the (-) to the ignition feed from the switch. Connect the (+) to the distributor points/condenser. The remaining lead should be the secondary led to the distributor cap.
Was your old coil from a magneto? I don't belief I have ever seen a battery ignition coil with four separate leads.
Electrically you cannot connect the primary leads, one to the ignition switch, and the other to ground, and have it work.Since you are working with DC current rather than AC in order for the magnetic lines of force to change to induce voltage in the secondary winding the primary winding must be turned on and off. That is the job of the points which must be connected to the grounded side. With the switch on and the points closed the current will flow through the primary winding and build up the magnetic field in the coil. When the points open the current flow stops in the primary winding which causes the magnetic field to collapse. The collapsing magnetic field induces the current in the secondary winding which will jump the spark plug gap when the voltage gets high enough.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
