It helps if you have an oven you can use to heat the flywheel so it slips on easier. Otherwise what I did with my Regular is I used bolts that I tightened into the block to pull the flywheel on. Just make sure you line up the hole in the process and drive the pin in afterwards. Helps to have assembly lube for the flywheel and the pin. And it also helps to have a bolt threaded into the pin as well so the pin is not hammered while being driven in.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
