Posted by farmall706 on July 02, 2011 at 20:59:50 from (50.103.51.225):
I have a 706 that has started acting funny. When you let the clutch out it takes off fine, but when you get rolling it will act like you have dis-engaged the clutch for a moment, then it will take off like you re-engaged the clutch, it will do this two or three times. There seems to be some sound like gear teeth slopping back and forth under the seat pedestal or like the gears are stopping and starting? The clutch is new and is adjusted as the manual states, The T/A is adjusted as the manual states.
The transmission brake is adjusted per the manual. Does the transmission brake stop the gear train when you dis-engage the clutch?
The transmission fluid has always been full, but when I checked it today it was low, I added two gallons on HY-Tran and it still is below the mark to add 1 gallon or more. Could the fluid being low cause this? I will get some more fluid tomorrow and fill back up. There are no leaks on the floor. Please advise if anyone has some thoughts are ideas. Thanks in advance for your time.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
