Going with Champion Spark Plug numbers, the original standard plug was a D16. That was then changed to D15Y. The plug has about the same effective heat range because it is one heat range colder but with an extended tip plug. The plug for light duty was D18Y. After leaded gasoline was phased out Champion changed the recommendation to D15Y for heavy use, D18Y for standard duty, and D21 for light duty.
Because the D21 is a pretty hot plug it can causes problems if used for heavy duty use. It can cause preignition if it runs too hot.
I use D21s in my I2444 with good results but that engine (C-153) is rarely used at more that about 2/3 throttle and light load. On my Super C with a 6 foot Wood mower I run D18Ys because that engine runs under much more load.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
