Posted by Pat-CT on July 02, 2011 at 20:43:37 from (68.9.37.25):
In Reply to: 59 cub lo-boy posted by cuttman on July 02, 2011 at 19:09:18:
How is the compression? is the timing correct? If you sue ether will it even attempt to start?. After you crank it with no success if you pull the lugs out are they wet? 3 things you need to make an engine run are compression ignition and fuel. Is the spark a good blue color?
What size batter cables are you using- perhaps your getting enough voltage to turn it over but not enough to get power to the coil. How is the battery. Check the plugs for gas after trying to start it Check compression on all four cylinders. Check timing If you have spark I doubt it has to do with the starter switch, if its turning over.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
