Posted by TheOldMan on June 29, 2011 at 06:39:53 from (74.51.5.129):
In Reply to: X in H serial # posted by carpman15 on June 28, 2011 at 12:40:23:
X1 remained the code for gas engines throughout production of the letter series Farmalls. I have a '49 with the X1 code on it, FBH399513X1. The kero code is X3, while the distillate code that was added much later is X17, prior to its addition, the absence of a code indicated distillate use, as that was the default, so to speak. I have 4 '40 models that are marked as such, FBH17867, 23075, 36586 and 40665. No codes on them at all, except for the last one, which is a special case in that it has the X1 code, but it was hand stamped to the left of the FBH, in the block where the letter 'H' normally appears by itself, indicating it was converted to gas at a later date, probably by a dealership. I also have a '41 model, FBH72515X6, which code indicated low speed gears, where the X6 code was also added by hand apparently at a later date, only it is in the correct location on the plate. That particular tractor does indeed have the low speed gear set in it, so again, probably converted by a dealership. The remainder of my H's (I have 10 in all) all have no codes on them, and all showed signs of having been original distillate tractors, though some were converted to gas in later years without the code being added to the plate. These were most likely done by the farmer himself or a jobber shop. I also have a '52 model M, FBK294174X1, where again the code looks to be hand stamped and is in the correct location. The only one I have not yet figured out, (admittedly I haven't researched much yet as I just bought it), is a '53 Super M sporting the number F34536J, with the 'J' appearing hand stamped. I don't yet know what the 'J' is supposed to stand for, and the 'F' is a bit of a mystery as well, as according to my guide books, the Super M was supposed to have 'SM' at the start of the serial number. This one has the 'SM' above it in the block indicating model. This is my first foray into the Super series tractors so I have a bit of learning to do on them.
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
