Posted by LRRifleman on June 26, 2011 at 18:09:28 from (173.101.76.147):
Hello!
While disking a field last week, I inadvertently ran my tank dry, and I have had problems since then starting the tractor. After I refueled, I could not get the tractor to start (I forgot abot bleeding the air from between the tank and the car). Then, I suspected the fuel filter may have become clog from suspended residue in the 52 year old tank. When I removed the fuel filter, I noticed difficulty in the fuel flow into the sediment bowl. I then removed the sediment bowl, and found excess "corrosion" and particulate build up in the "petcock assembly". I then replaced the sediment bowl and petcock assembly. I still could not get the tractor started, then remember (upon seeing the fuel "trickle" into the new sediment bowl ssembly, that I had to bleed the air out of the gas line. I still have trouble starting the tractor. Today, I took apart the carb and cleaned the needle and jet. Still, the tractor does not start. I then checked the points and rotor, everything seemed in place. In turning the tractor over, it fires up for less than 5 seconds, and sounds like it is firing on only 2, maybe 3, cylinders. Meanwhile, while the starter turns over, the motor and tranny sound like a thrashing machine. All fluid levels show full. After repeated attempts to start the tractor (unsuccessfully) today, I beleive I drained the battery, so that only the starter "clicks" and the tractor will not catch.
Would anyone care to venture a guess as to what is wrong with my tractor to explain why I can't get it to start? As an aside, when I bought the tactor back in '09, it had had th engine (top) overhauled, and since then,I guess I hadput on maybe 40 hours (the tach was disconnected until this past winter whn I had th carb rebuilt and the hydraulics overhauled).
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
