Posted by JRSutton on June 17, 2011 at 12:35:12 from (75.130.109.233):
My Super A is leaking like a seive from the bottom of the differential/rear axle case where it attaches to the transmission case.
This is a new tractor to me - and I know nothing about the innards here. I've looked at various cross sections in manuals, but figured I'd check here before diving in.
First of all, I'm assuming there shouldn't be anything in there TO leak, as that's where the brake drum is.
So therefore I'm assuming I have a bad seal in the transmission case where the differential shaft goes through, and that's where the oil is coming from.
So I'm figuring I have to pull the differential shaft and change the seal - perhaps redi-sleeve the shaft if it's badly worn?
By the way, this is on the left side of the tractor - the short side.
So I'm thinking all I have to do is prop the tractor up securely - pull the wheel off - then take the bolts out for the differential case from the transmission and pull it all straight out...
Assuming this is how I'd change the brake linings, so it can't be THAT hard to get in there... right?
or am I fooling myself that this will be a fairly easy job?
Any tips,tricks, issues to avoid, etc would be greatly appreciated.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
