The purpose of the warning light is to: 1 - Warn if the ignition is "on" and the alternator is NOT charging, and 2 - Limit the backflow current from the alternator when the alternator is charging and the ignition switch is opened. (Without the lamp the backflow current is sufficient to continue to fire the coil when the ign is switch opened. End result is the engine will continue to run after you shut the ignition off.)
The diode serves the same purpose as #2 - it prevents backflow current from the alternator to the coil when the ignition switch is opened. On the VAC the manual switch accomplishes the same thing.
On your MD the oil pressure switch together with the manifold serves a surrogate for ignition switch on a gas tractor.
A ballast resistor is not required if the coil is a "self-ballasted" (ie. 12 volt) coil. It has the required resistance incorporated within the coil primary winding.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
