Posted by Shawn in PA on June 12, 2011 at 14:11:34 from (24.154.38.87):
SM got a pretty steady miss on #1 cylinder. Just did the head gasket about a month ago, and changed out the plugs, wires, cap, rotor, points ect. So I proceeded to check the manifold studs, and all were tight. Passed the propane test. I suspected a stuck valve, but after a compression check, it turns out that wasn't the case. All the valves were set to tolerance and still tight. No bent rods. Timing wasn't off either. Turns out, the new Autolite spark plug in the number 1 hole had failed... Swapped in a D-21 from my H and it purred as it should. Moral of the story, start with the simple stuff first, and don't assume new parts don't fail right out of the box...lesson learned. Shawn
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
