Clutch is removable through an opening in bottom of clutch housing. The procedure is as follows:
1). Remove four bolts from the clutch joint. (Marked 1 in picture)
2). Remove clutch release sleeve carrier. (Marked 2 in picture)
3). Remove clutch shaft together with thrust bearing.
4). Remove three cap screws holding clutch to flywheel and after placing washers under the head of cap screws replace transpose them to the three holes provided for compressing the clutch spring.
5). Remove the remaining cap screws and lift out clutch.
6). Reassembly is made in the reverse procedure, but be sure to install clutch shaft before releasing pressure on clutch springs and be sure to assemble clutch joint ring with convex side toward clutch.
Good Luck! SadFarmall
This post was edited by SadFarmall at 16:11:30 06/11/11.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
