Posted by pete 23 on June 08, 2011 at 10:31:48 from (74.32.230.16):
In Reply to: Glow plugs?? posted by Bud DeLong on June 07, 2011 at 20:14:54:
I like to take out a glow plug and hook the wire back up plus add a ground wire and then see if if heats up red hot in about 20 seconds with all glow plugs working. If so your wiring etc is good, other wise not. If it will do that then your problem is actually the condition of the engine. Wear and build tolerences like piston protrusion, valve recession are the main issue. Injection nozzles rarely cause hard starting problem, pump could but that will be more noticable when engine is warm than cold. Static timing is a big issue. Many are set too far advanced because the automatic advance isn't working properly. They do this to make it run smooth at high speeds but is not the way to do things. Advance is adjustable and requires frequent adjusting as a rule to be correct. Just a tad of wear on the tip of that metering valve and or guide stud and it be out of wack. Luckily they are easy to adjust and easy to determine if out of adjustment. Kind of got off the glow plug subject but just thought I would throw that in.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
