The most likely cause is a failure of the IPTO hub and shaft/gear in the back of the clutch pressure plate assembly. If you remove the cover under the clutch you can see the parts in front of the release bearing. Make sure the shaft and hub are turning with the PPA.
When the splines wear out they usually make noise for a little while but if run enough they will quiet down as they splines wear more. The rivets that hold the hub to the clutch cover may be what failed. In that case they will make little or no noise.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
