Posted by oldtanker on May 31, 2011 at 10:42:56 from (66.228.255.223):
In Reply to: 706 diesel posted by 4 bottem on May 31, 2011 at 10:23:20:
As for the plow you are dead on. It's not measure in how many bottoms you pull it's how many acres an hour. A tractor pulling 5 16's in 2 low is not going to plow anywhere near as much ground an hour as the same tractor plowing in 4 low with 4 16's.
Now as far as disk goes. Local used equipment dealer whos main customer base is small and hobby farmers says 2 ft of disk for every 10 HP at the drawbar as a rule of thumb. The thing to remember that if you max everything out all the time something is going to wear out or break. If you go just a tad smaller without going to fast for the implement you break down less.
Nebraska test cliams about 62.48 drawbar HP on the 706. You should in light sandy soil be ok with 14' of disk.......I have a 14' disk behind a 94 HP tractor at the drawbar. In lite sandy soil unless I'm running blocks to keep the disk up some it will pull fine in 4low but 1 high isn't good. I would suggest a 12 Ft disk for the 706.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
