Posted by SouthernFarmall on May 25, 2011 at 10:59:16 from (76.4.24.140):
In Reply to: Re: IH 274 posted by karl f on May 25, 2011 at 10:38:07:
That is a very good point about the PTO on the Cub. There are many more problems with Cubs that bear thought, such as the so-called "quick attachable" hitch system. Using this method, It takes approximately 35 minutes to take off a plow and put cultivators on the Cub. This is opposed the Fast Hitch, where I can switch from plowing to cultivating in under 10 minutes.
And, while I do agree that the placement of the shaft is nonstandard, it doesn't pose that much of a problem. I tedder hay often with a 140, and the PTO shaft position is only a problem when making very sharp turns (because the tedder shaft can hit the fast hitch). You mentioned that implements are hard to find for a fast hitch. While that is true, it is actually very easy to bolt or weld a fast hitch bar (available at Agri-Supply) to the 3 point implement. While I do have "real" 140 plows and discs, I also own a rake and scrape blade that have been fabricated in the manner I mentioned.
In my opinion, the offset design does have flaws, but none are serious enough to hamper performance. In fact, I believe that offset tractors have enough good points to put them far ahead of standard tractors in usefulness and versatility.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
