The best way to do the adjustment is to use a flat surface and a spacer as thick as the lever height measurement. Use a heavy washer to catch all three levers and a bolt through your surface plate or a small plate and a press to hold the levers at the spacer height. Then adjust the levers until you get the right measurement between the surface plate and the underside of of the clutch cover where the mounting bolts are located.
An alternate method is to use the correct height spacers under the clutch cover at the mounting holes and pull the cover down until they are tight. Then adjust the levers until you get the correct lever height.
The first method is best because that has the adjustments made with spring pressure against the levers to take up any movement between holes and pivot pins. With the second method there is no tension on the levers and any adjustment may be off due to worn parts.
Usually you are better off not trying to make any adjustment on the clutch levers because it is very difficult to get the adjustments set as close as a rebuild PPA is set to.
If you really have to make adjustments without the proper setting tools you can get pretty close by having the flywheel off and setting it on a level surface. Once the flywheel is level install the disk and PPA. Adjust the levers until they are horizontal. Use a heavy washer or small plate that will cover all three levers. Put a level on the plate and do final adjustments until the plate is level.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
