Posted by mkirsch on May 21, 2011 at 05:37:47 from (67.253.161.186):
In Reply to: IH #8 Plow posted by IAtractorKid on May 20, 2011 at 19:57:36:
There are two models of #8 3-bottom plow. One can be reduced to 2-bottom (#8), the other can't (#8L)
A #8L plow will have a wider pull bar and a third main beam in between the two that are attached to the pull bar.
On a #8, the third bottom will flare out from the second bottom and kind of "stick out" to the left as you sit on the tractor. It LOOKS like it was added on.
Removing the bottom is as simple as unbolting the tail wheel, the beam and the brace. Bolt the tail wheel to the corresponding holes on the second bottom.
The only part you might need is the 2-bottom lift arm for the tailwheel. On the 3-bottom #8, the tailwheel lift arm is bolted to the axle leg outside the frame. On the 2-bottom, the lift arm is clamped to the axle shaft in between the 1st and 2nd bottom beams.
Other than the heavy lifting, it is easy and obvious.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
