Posted by pete 23 on May 15, 2011 at 11:05:40 from (74.44.100.190):
In Reply to: 460 Fuel Sending Unit posted by gearheadbill on May 15, 2011 at 10:54:45:
You mean original equipment type gauge , right. Same as 560, don't know why you can't find one at CASEIH. The sending unit has to match the gauge as one mfg uses a sending unit with increased resistance when reading full, and the other is decreased resistance when full. Hook sender up to gauge before installing, provide a good ground also and check your readings to see if it is correct. I just put in gauge and senders on 460 and a 656 and they were opposites of each other. In fact, I used the old sender out of the 656( that some one had Jury rigged for a seperately mounted gauge) and put it in the 460. The 460 shows full with key off, 656 shows empty with key off. Both read correctly for position of sender.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
