That engine will run on diesel cycle if you show any pressure at all on the primary pump gauge. May not have any power but will run. What part of the pump did you take apart, primary or high pressure. Did you adjust injection nozzle pressures to about 700 psi. Will it shoot a good stream out of injector bleeders when running on gas cycle and with some throttle. Make sure the decompression valves are not all stuck open. You can tell that easily by removing the spark plugs and cranking engine over on diesel cycle with starter. If they are closed and sealing no compression will come out of spark plug holes.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
