The timing is set at full throttle at 30 degrees btdc. Then it should gradually retard as you lower the engine speed and be close to tdc at low idle rpm of about 500. If it doesn't respond that way you need to repair the advance mechanism in the distributor. It does not have to be fully retarded to tdc if it runs ok at low rpm and the static timming (engine not running) is at tdc which is checked by seeing when the points just start to open. A worn distributor will normally advance way to early and the timing will bounce around back and forth. If you try to set the timing with the timing light only at low speed it may very well already be partially advanced and therefore your top end will be late and it is the top end that you need to be concerned with. With todays lower octane gasoline you may want to back off the top end timing a few degrees if you are pulling it hard and long. If you have good ears you can hear a ping and adjust accordingly but I havent't heard a ping if over 50 years.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
