If you know how to use a volt meter you can find the problems instead of just throwing parts at it. With the starter engaged there should be no more than .1 volt drop in any wire, .2 volt drop through any connection, but no more than about .5 volts drop from the battery post to the starter terminal. Also check the grounded side. You should have no more than about .2 volt drop between the starter and the battery post. Battery voltage during cranking should not drop below 9 volts. Starter amperage draw can be determined by reading the battery voltage during cranking and then have the battery load tested to the same voltage and read the amperage.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
