The 6 volt systems didnt crank over at any real fast RPM to begin with (depends on temp of course) but if the battery is stong and a heavy rated unit and you use 00 gauge Battery n Starter n Ground cables, a decent H should start okay if the battery n starters in decent shape.
First thing Id do is remove, clean n wire brush, n re attach all battery n starter n ground cables and make sure the battery is good n see what happens and replace the cables with 00 if they happen to be thin and wimpy...
A bad resistive burned starter switch can cause poor cranking also, even if all else is fine, you may wanna take a look at that possibility.
If you only put 6 volts on a 12 volt starter it will crank slower then molasses in January.
You ask "If it is actually a 6v starter, will I damage it with a 12v battery?? "
ANSWER you probably wont damage it (12 on a 6 volt starter) just dont let it crank too long although it can be a bit tougher on starter drives.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
