Rob Maloney said: (quoted from post at 01:40:16 04/28/11) Thanks for your reply. Seems like I read in a manual that the Lift-All pump only had a capacity of 850 psi. The cylinders are small (probably 2"). Would larger cylinders command more lift, even if the pump is maxed at 850 psi? Thanks.
Lifting force increases by the square.
2x2=4
3x3=9
consequently, 9 divided by 4 equals 2.25 as much lifting power.
You could also use only one 4" x 8" cylinder and get 2 times the lifting capacity out of the hitch which I presume is a Worksaver brand. 2 ea 3" cylinders or one 4" should lift the bale but it depends where the adjustable lift links are attached to lift arms. I believe there are three holes/positions.
This post was edited by Wardner at 05:33:44 04/28/11.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
