Posted by mkirsch on April 27, 2011 at 05:12:14 from (64.80.110.75):
In Reply to: Single bottom IH plow posted by James Williams on April 26, 2011 at 19:02:59:
With a 1-bottom plow, there's only ONE landside. I guess it could be the "rear landside" but it's also the "front landside."
The landside is what presses against the side of the newly-cut furrow, and keeps the plow running straight. It is down on the lower left side of the plow bottom.
If you're trying to run with worn-out, broken, or missing parts, you can't expect the plow to work right.
Did you adjust the tongue on the plow to make trail behind the tractor? If you swung the tongue too far to the left, the plow will just want to straighten out behind the tractor when you drop it in the ground.
If you sight straight backward from the end of the tongue, you should be at least in line with the landside edge of the bottom. Actually, you should be somewhere in front of the bottom. Anywhere to the left of the bottom will cause the plow to pull crooked.
A 1-bottom plow requires a narrow tractor like an A or B, or it must be hooked far off to the right on the hoop drawbar of an H or M.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
