Posted by Jimb2 on April 24, 2011 at 17:45:13 from (204.237.121.150):
In Reply to: IH 574 injector pump posted by B.Evers on April 24, 2011 at 14:11:36:
Hi B, hoped you lined up the timing marks and scribed everything as you should not have removed or even loosened the 3 cap screws on the pump drive gear. All that was required was to remove the big nut on the pump drive shaft. The pump drive shaft is a tapered shaft with a woodruff key in the pump drive gear. The approved method to remove the pump drive gear from the drive shaft is a special puller tool from IH. I screw the big nut off the drive shaft, put a piece of hardwood against the end of the shaft and give it a sharp tap with a hammer. Be careful not to damage the threads on the drive shaft. Also leave one of the nuts on the pump mounting bolts screwed on a couple turns so when you tap the drive shaft the pump doesn't go flying out onto the ground.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
