Posted by Janicholson on April 22, 2011 at 19:34:20 from (67.72.98.45):
In Reply to: Cracked? Useable? posted by caseman-d on April 22, 2011 at 16:37:15:
Cracks like those can and do cause water leaks down between the sleeve and the block casting into the oil pan. The situation is now a decision between getting a replacement block, or having it bored to receive a repair sleeve, then rebored to accept the normal dry sleeve, or thinner sleeves to make it displace the same as a Super M. If it is already using the Thin sleeves, no issue doing one hole, but it does require tear down for machine work, as noted in the other post. A very modest sanding of the cast bore is OK, honing is almost never done as the bores are often looser than desired when refit with sleeves. Sleeves need to be chilled and block warmed , then usually driven in with a block of wood after slipping in 1/2 to 2/3 of the way pretty easily. A different block might be a better option in this case. Jim
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
