Posted by Seth Boyer on April 21, 2011 at 19:45:09 from (75.120.184.218):
In Reply to: mw clutch posted by old mack on April 21, 2011 at 12:59:24:
John when I was rebuilding my M&W clutch on my H I ended up destroying most of the fiber discs. When you get everything off down to the discs you should be able to tell how the outer circumference of the fiber discs and the inner part of the drum are splined. In my experiance there was enough corrosion built up that it did not allow the fiber discs to just pull out easily. Maybe with enough patience you can use a file...wire brush...ect... to clean it out and this would allow you to pull them out. Then of course between each fiber disc will be a metal plate that will have splines on the inner shaft. Good luck.
I know where you can get parts if you need them. Let us know what you run into.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
