First check the single to double action settings on the aux valves. One may be turned too far bending or breaking the roll pin and that will cause system to stay on demand. The 560 is not really a true open center valve system as there is no flow through aux valves when in neutral, the flow from the pump is diverted to reservoir through the regulator valve ( unloading valve). This valve is controlled by a screened orfice under the cover of reg valve. If plugged or peened undersized it will cause your system to stay on demand , fluid going over relief valve portion of regulator valve assembly. Clean or replace orfice if plugged. More information on other posts previous to this one.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
