130 loose steering
Posted by caspermj on March 30, 2011 at 06:03:44 from (142.68.81.97):
Hi all,
I've noticed that there is a booger weld (broken, and now very loose) between the steering (pitman?) arm and the large castelated nut holding it to the steering box shaft. Basically, what you'd be looking at from the front of the tractor and looking into the opening of the steering box. When I move the steering wheel, that nut moves instantly with it, but the pitman arm doesn't for about a 1/4 turn on the wheel. Is it safe to "assume" that the splines on the shaft and or arm are worn/gone? Any suggestions where I should go from here? Thanks.
~Roy
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
