The mag is equipped with an impulse coupling. This device is a spring loaded trigger operated mag component that speeds up the mag internal magnet. At cranking speeds the magnet turns so slowly that the voltage it produces in the coil is not sufficient to make reliable spark. The mechanism locks at each cylinder location and as the engine turns, it winds the spring. when the engine gets to TDC, it triggers the release of the spring, allowing the magnet to leap faster for a fraction of a second. this makes nice fat spark. When it sparks the tractor starts, and the impulse system is disengaged the running tractor has all the speed it needs to make spark level voltage in the coil. It also advances the spark to full advance for running and work. It is set at TDC for the impulse to prevent backfiring and kickback when cranking manually or with a starter.
To fix yours, the impulse coupling needs to be cleaned out and lubed with a PTFE spray like Tri Flow. Set the #1 piston at TDC on the timing mark, with the mag rotor pointing to (or near the #1 plug wire terminal on the cap. If you carefully remove the mag, and do not move the engine, putting it back in is not an issue, if it ends up pointing at the same location. Be careful with internal parts, there is internal timing marks on the rotor shaft as well. Best of luck. Jim
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
