Posted by RTR on March 28, 2011 at 08:47:28 from (216.226.179.180):
What I"ve got: Farmall Cub Tractor Serial #24,610 6 Volt Positive Ground System 6 Volt Generator Distributor Ignition New 6 Volt Battery & New Cables Voltage Regulator System (pretty sure, it has ODB light switch and not the LHDB switch)
1st Issue: When the battery cables are hooked to the posts; there is a spark. Cause: ? Possible Bad Ground ? Solution: ?
2nd Issue: Once battery cables are hooked up, the ammeter shows a discharge of about 10 amps. Tractor is not running and no switches are on. Cause: ? Solution: ?
3rd Issue: I try to start the tractor, and when started switch is engaged, it just makes a loud "pop" at the battery connection and never engages starter. Cause: ? Solution: ?
4th Issue: When I try to "reconnect" the battery connection I notice that the battery cables are fairly Warm. Cause: ? Solution: ?AL Farmall Boy Cub Star
Posts: 99 Joined: Tue Aug 10, 2010 6:38 pm Zip Code: 35111 Private message
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
