Posted by Janicholson on March 20, 2011 at 14:46:38 from (67.72.98.45):
In Reply to: H Argh! posted by pete_5959 on March 20, 2011 at 14:34:40:
Pulling the oil pan will tell you the story. If a rod broke and destroyed internal surfaces, oil pump and or the block itself, it will require substantial effort to make it right. The most common problems that make internal noise are broken rods, spun bearings and broken crankshafts. All are visible with the pan off. If the block and cam are OK, and the crank was untouched, A engine Kit will be all that is needed. If there is damage to the journals and block it might just be best to get a different engine and rebuild that. Super H or 300-350 would be nice! If the crank is measured and found to be good, and the block is OK it might be an in frame proposition. Otherwise the engine will need to be removed. Jim
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
