Posted by pete 23 on March 13, 2011 at 10:52:33 from (173.87.146.142):
In Reply to: F460 Hydraulic Noise posted by SteveF460 on March 13, 2011 at 05:39:04:
Did your orfice screen have a check ball in it or did it have one previously. If it did there will be a hole for a roll pin to hold ball in place. What happens with those is the check ball bounces back and forth and closes the orfice hole too small. It should be .031 when new. I drill them out a little to make up for leakage agcross the regulator valve land in the hydraulic valves. So , depending on what you have for an orfice will determine your course of action. It is a trial and error to get the correct size, too small it will go on demand intermitently or constant when warmed up good, too large a hole and it will not go on demand. .040 would be a starting point. If it quiets down when on demand you are most likely ok with the filter and or sucking air situation.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
